Android Development on FydeOS
Last Update: 2025-08-14
In 2016, Google expanded the Android ecosystem by integrating the Android operating environment into ChromeOS. This move opened the door for desktop Android apps designed for large screens and keyboard and mouse operations. Over the years, Google has made significant enhancements to the Android environment on ChromeOS, encouraging more manufacturers and developers to get involved. In May, Google’s open-source project, Project Crostini, brought a native Linux experience to ChromeOS, enabling daily development and debugging work on ChromeOS.
During the annual Google Developers Conference (Google IO), we witnessed the installation of Chrome on a Google Pixelbook during a presentation on “What’s new in Android apps for ChromeOS”. This Pixelbook supports large Linux apps like Android Studio and allows direct debugging and compiling of Android apps via ADB and the onboard Android environment, marking a significant milestone in the promotion of the Android desktop ecosystem.
FydeOS is a desktop operating system based on ChromiumOS. It decouples the originally tightly bound Google services and adds self-developed modules and optimizations, making it more accessible to users without easy access to Google services.
This guide will walk you through enabling the Linux subsystem in FydeOS, installing and running Linux apps, and working with the onboard Android environment to achieve high efficiency on ChromeOS + Pixelbook, as demonstrated at Google IO.
  1. Download FydeOS from the official website
  2. Flash FydeOS to a portable storage device following the setup guide
  3. For best performance, we recommend installing FydeOS as the sole system. If you need dual-boot setup, please refer to our dual-boot guide.
  1. Open “Android” from the application launcher
  2. Navigate to “System” -> “Developer options”
  3. Enable the “ADB debugging” option
  1. Open “Settings”
  2. Locate and click on “Linux” settings
  3. Click “Turn On” and follow the installation prompts
  4. Wait for the Terminal app to appear in your launcher
  1. Download Android Studio for ChromeOS from developer.android.com
  2. Double-click the downloaded file to begin installation
  3. Follow the initialization wizard
  4. Download required SDK and toolsets when prompted
  1. Open a new Terminal window
  2. Install ADB by running:
    Terminal window
    sudo apt-get install adb
  3. Connect to the Android subsystem:
    Terminal window
    adb connect 100.115.92.2:5555
  1. Ensure ADB debugging is enabled on your device
  2. Locate your FydeOS device’s IP address
  3. Connect using: adb connect <device-ip>:5555
Need help? Here are some useful resources:
