Setup Linux Input Methods
The Linux subsystem built into FydeOS currently doesn’t support the system’s native input method. This poses a challenge for users needing to input non-English languages, particularly for CJK native speakers. To overcome this, you can install a third-party input method for the Linux subsystem. This guide will walk you through the process of installing and configuring the Fcitx input method on FydeOS’s Linux subsystem.
Installing the Fcitx Input Method
Section titled “Installing the Fcitx Input Method”- Launch the Linux terminal and wait for the Linux subsystem to boot up.
- Update your software sources and applications:
Terminal window sudo apt update && sudo apt upgrade - Install the Fcitx input method:
Terminal window sudo apt install fcitx fcitx-lib* -y
Setting Fcitx as the Default Input Method
Section titled “Setting Fcitx as the Default Input Method”- Run the following command in the Linux terminal (do not run as root):
Terminal window im-config - Follow the dialog prompts:
- Click “OK”
- Click “Yes”
- Select “fcitx”
- Click “OK” twice
Configuring Fcitx Settings
Section titled “Configuring Fcitx Settings”- Launch the configuration tool:
Terminal window fcitx && fcitx-configtool - In the configuration window:
- Click the “+” button in the bottom left corner
- Uncheck “Only show current language”
- Select your desired input method
- Click “OK”
If no input methods appear:
- Close the window
- Run
fcitx-diagnose - Repeat the configuration steps
Setting Fcitx as the Language Input Environment
Section titled “Setting Fcitx as the Language Input Environment”- Install gedit text editor:
Terminal window sudo apt install gedit -y - Open the configuration file:
Terminal window sudo gedit /etc/systemd/user/cros-garcon.service.d/cros-garcon-override.conf - Add these environment variables to the end of the file:
Terminal window Environment="GTK_IM_MODULE=fcitx"Environment="QT_IM_MODULE=fcitx"Environment="XMODIFIERS=@im=fcitx" - Save and close the file
Setting Fcitx to Auto-Start
Section titled “Setting Fcitx to Auto-Start”- Modify the auto-start options:
Terminal window sudo gedit ~/.sommelierrc - Add this line to the end of the file:
Terminal window /usr/bin/fcitx-autostart - Save and close the file
- Restart the Linux subsystem:
Terminal window sudo reboot - You can now switch between input methods using
Ctrl+Space
