Keyboard Shortcuts Guide
Last Update: 2023-07-18
In FydeOS, keyboard shortcuts are a powerful tool that can help you accomplish tasks more efficiently. To search for specific shortcuts on this page, press Ctrl + f and type your query.
Action Shortcut
Screenshot (full screen) Ctrl + F5
Screenshot (partial) Shift + Ctrl + F5
Screenshot in tablet mode Power button + Volume down button
Toggle Caps Lock ❖ (Win key) / ⌘ + Alt
Log out of FydeOS Shift + Ctrl + q (twice)
View all shortcuts Ctrl + Alt + /
Action Shortcut
Open new window Ctrl + n
Open incognito window Shift + Ctrl + n
Open new tab Ctrl + t
Open file in browser Ctrl + o
Close current tab Ctrl + w
Close current window Shift + Ctrl + w
Reopen last closed tab/window Shift + Ctrl + t
Navigate tabs 1-8 Ctrl + 1 ~ 8
Navigate to last tab Ctrl + 9
Navigate to next tab Ctrl + Tab
Navigate to previous tab Shift + Ctrl + Tab
Switch windows Alt + Tab
Open least recently used window Shift + Alt + Tab
Navigate browsing history (back/forward) Alt + ← / Alt + →
Open link in new tab (background) Ctrl + Click link
Open link in new tab (foreground) Shift + Ctrl + Click link
Open link in new window Shift + Click link
Open link in tab Drag link to tab’s address bar
Open link in new tab Drag link to empty tab bar area
Open URL in new tab Alt + Enter
Reset tab position Esc (while dragging tab)
Window management (pin left/right, maximize, minimize) Alt + [ / Alt + ] / Alt + = / Alt + -
Switch windows between screens ❖ / ⌘ + Alt + m
Action Shortcut
Page up/down ❖ / ⌘ or Alt + ↑ / Alt + ↓
Scroll down Spacebar
Go to top/bottom of page Ctrl + Alt + ↑ / Ctrl + Alt + ↓
Print page Ctrl + p
Save page Ctrl + s
Refresh page Ctrl + r
Hard refresh (ignore cache) Shift + Ctrl + r
Zoom in/out Ctrl + + / Ctrl + -
Reset zoom Ctrl + 0
Stop page loading Esc
Right-click link Alt + Click link
Save link as bookmark Drag link to bookmark bar
Bookmark current page Ctrl + d
Bookmark all open pages Shift + Ctrl + d
Find in page Ctrl + f
Find next/previous match Ctrl + g / Shift + Ctrl + g
Add www. and .com to search bar entry Ctrl + Enter
View page source Ctrl + u
Toggle developer tools Shift + Ctrl + i
Toggle DOM inspector Shift + Ctrl + j
Toggle bookmark bar Shift + Ctrl + b
Open History page Ctrl + h
Open Downloads page Ctrl + j
Delete autofill suggestion Shift + Alt + Backspace
Action Shortcut
Open “Files” app Shift + Alt + m
Preview file in “Files” app Select file + Spacebar
Show hidden files in “Files” app Ctrl + .
Open status area Shift + Alt + s
Click taskbar icons 1-8 Alt + 1 ~ 8
Click last taskbar icon Alt + 9
Use Fn keys (F1-F12) ❖ / ⌘ + 1 ~ =
View notifications Shift + Alt + n
Change screen resolution Shift + Ctrl + + / -
Reset screen resolution Shift + Ctrl + 0
Rotate screen 90 degrees Shift + Ctrl + F3
Switch to next/previous user Ctrl + Alt + . / Ctrl + Alt + ,
Action Shortcut
Toggle Caps Lock ❖ / ⌘ + Alt
Select all Ctrl + a
Select address bar content Ctrl + L or Alt + d
Select next/previous word or letter Shift + Ctrl + → / Shift + Ctrl + ←
Select to end/beginning of line ❖ / ⌘ + Shift + → / ❖ / ⌘ + Shift + ←
Move to end/beginning of next/previous word Ctrl + → / Ctrl + ←
Move to end/beginning of document ❖ / ⌘ + Ctrl + → / ❖ / ⌘ + Ctrl + ←
Copy Ctrl + c
Paste Ctrl + v
Paste as plain text Shift + Ctrl + v
Cut Ctrl + x
Delete previous word Ctrl + Backspace
Delete next letter Alt + Backspace
Undo Ctrl + z
Redo Shift + Ctrl + z
Switch keyboard languages Shift + Ctrl + Spacebar
Switch to last used keyboard language Ctrl + Spacebar
Dim/brighten backlit keyboard Alt + F6 / Alt + F7
Action Shortcut
Toggle ChromeVox (voice feedback) Ctrl + Alt + z
Highlight launcher button Shift + Alt + L
Highlight next/previous taskbar item Shift + Alt + L + Tab / Shift + Alt + L + Shift + Tab
Open highlighted taskbar button Shift + Alt + L + Spacebar or Enter
Cancel taskbar button highlight Shift + Alt + L + Esc
Highlight bookmark bar Shift + Alt + ·
Highlight address bar Shift + Alt + t
Open context menu of highlighted item ❖ / ⌘ + Shift + F10
Zoom entire screen ❖ / ⌘ + Ctrl + m
Zoom part of screen ❖ / ⌘ + Ctrl + d
Switch focus between panes Ctrl + F1 or Ctrl + F2
https://support.google.com/chromebook/answer/183101
